As a warning to you all... I am very much a newbie to this but have studied the guides to try understand the process.
I have a number of clips with some in AVI and others MPG that I wish to put on to the same SVCD. What would people suggest as the best way of carrying this out? (Preferably not "don't")
I tried to do a VirtualDub "Save as AVI..." but got some error (think it was related to the audio but can't check to confirm the error until tonight). Would this be an appropriate approach or is there a far wiser method?
I assume the MPG files need to be converted to MPEG-II first? Is there a tool to carry out such?
If this turns out to have an obvious answer... my apologies!
Thanks in Advance
Ryan
just follow this guide ..
https://www.videohelp.com/tmpgencsvcd.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i thought you said that you had avi files ?, and yes that is basically how you do it.
I do, have no problem with the AVI part of it. What I want to do is have both the AVI and MPG files converted on to a SVCD (together). But if tmpgenc is happy to run through an MPG file then fantastic, will give it a run asap.
On that note, I assume there won't be issues with audio like can be experienced with AVI or is it possible the MPG won't convert?
Thanks all!
Ryan -
Just use the standard svcd template in TMPG. As long as the audio in your original files are not AC3 or VBR TMPG will convert it to svcd standard without protest.
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 17:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
avi to mpg
By zoranb in forum Video ConversionReplies: 7Last Post: 12th Sep 2007, 16:09 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
