I have a DVD that was ripped from the European Version of Jungle Book 2 (with SmartRipper). When I open the ripped DVD with DVDEncrypter it shows it to be region-free (i.e. all Regions are enabled: 1,2,3,4,5,6,7,8). When I try playing the DVD with Power DVD it says it is only region 2 and asks me if I want to change the region setting of my DVD drive (which I do not). My standalone Sony DVD player also doesn't allow playback due to region conflict.
How is it possible that one program reports it to be region free while another program/player still recognizes the original region setting? The DVD+R media was purchased in Europe. Is it possible for region information to be embedded in the blank DVD media? Any help is greatly appreciated.
So your are ripping a European dvd and it says it is region free ?, does it say this on the box because I would be very suprised if a company like Disney would ever release a region free dvd.
The original DVD was of course encrypted and only region 2. When copying the DVD to DVDR, Smartripper was used in order to read the DVD content and make it region-free. As a result the ripped copy is unencrypted and region-free (at least according to DVDDecrypter).
why not try using DVDDecrypter and ripping it instead?
this sounds similar to the Simpsons Region problem as you had to rip it keeping the region info and remove it after but I'm not so sure if it will be the same issue
DVD Region problem
By elty in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 09:39 -
region 2 dvd problem
By aprilluis in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2010, 18:47 -
LG RH2T80 Region code problem
By Travel Ted in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2009, 06:04 -
Problem with Region settings
By paulgold in forum DVD RippingReplies: 11Last Post: 18th Apr 2008, 21:47 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 04:36
