Anybody knows how to encode two audio tracks ( original language and dub) using SVCD ?
Reading the specs , I understand that SVCD can have two audio tracks and You can select the desired when see the movie but don´t teach how to make it.
Regards,
alb1n0
Hopefully, you are using bbMpeg 1.24b18 to mux your final files, right? If so, in the input/output files tab under settings, you'll notice a second audio field. Put your primary audio in the first audio track field and the secondary in the second audio track field.
I've done this several time. I'll usually get the normal audio track and encode it at 128kbs. If there is a commentary track, I'll encode it at 64kbs since it's usually voice over music and make that the audio #2. Very cool, however, you'll have to adjust your bitrate calculations if you are still trying to sqeeze them onto 2 discs.
Thanx for your attention, I catch "how-to",but there is other question :
-How to select the desired audio track , when I want to ear
the original soundtrack and when I want the dubbed soundtrack? This is a work for the player or is needed make
something when authoring ??
alb1n0 -
You hit the audio button on your remote to toggle between languages. You cannot assing the languages to a button like with a dvd.
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 23:54 -
Program switches audio track priority of dual-audio assets
By PBear in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 16th Nov 2007, 20:36 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 14:53
