I have captured a .avi file from my Sony Digital8 Camcorder and tried to encode it using Dr. Divx. The audio and video play fine when I capture it, but after encoding it using Dr. Divx, the video is fine, but the audio is very low pitched and very slow. Is this a problem with how I am capturing the file? I am using a firewire connection and have captured using various applications. Is this a Type-1 versus Type-2 problem? If so, which one should I be capturing with and which applications will let you specify?
Thanks for all advice.
Results 1 to 1 of 1
Video encoding - How low can CRF values go?
By mpalm887 in forum Blu-ray RippingReplies: 26Last Post: 14th Feb 2012, 09:24 -
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
Best Encoder when encoding with low bitrates
By MI6 in forum Video ConversionReplies: 6Last Post: 27th Nov 2010, 21:37 -
Low Cost Hardware for Xvid encoding
By WildParadise in forum Newbie / General discussionsReplies: 50Last Post: 24th Apr 2008, 15:13 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 19:42
