Ok, I have tried virtually every option for this...I got a BIN/CUE file which was an SVCD, and I extracted the video (which I followed all of the intructions that were in various parts of this site), and I first tried to author it like it was onto a DVD, which obviously didn't work, as its 480x480...so, I downloaded (S)VCD2DVD, and I have tried the conversion with the BIN files, and the MPG files, my only problem is resizing, and everytime I tried the different sizes with this program, it made the video look terrible...I tried resizing the whole file, and just the header as well...what can I do to convert this to the proper DVD size? Is there some kind of program? I have TMPGEnc as well, but when I tried editing with that, I got some kind of error. Ugh, I have been working on this for the past few days, and have had absolutely no luck.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
(S)VCD2DVDMPG prepares your files for authoring. if you play these files before you author they will look wierd. once you've finished with svcd2dvdmpg, author with your authoring application & then use svcd2dvdmpg to patch back to 480. It will then look like it did @ svcd when viewed by a dvd player.
Ah, thanksOriginally Posted by ChrissyBoy
thats a huge help, I wasn't sure how the reconfiguring of the vob file would work, but nevertheless, it worked!
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
