Hi I have a avi file approx 50 minutes that I want to convert into VCD so I can watch it on a standalone DVD Player. I used Nero 5.5 and just dragged the file to the VCD wizard and worked fine but the problem is the VCD came out upside down. Is there ways I can fix this ? In addition I was gonna use TMPGE to re-encode into MPEG and then burn it but it requires 2 CD. Can someone tell me how come it was possible for Nero to fit everything on 1 CD but it required TMPGE 2 cds ? And are there any other good alternative solution so I can burn it to 1 VCD having it come out the right way. Thanks.
It should not require 2 cd's if you use TMPGEnc to encode it. Are you sure you are using the right template? You should be selecting VCD and not SVCD - you should be able to put ~80 Min. on a CD in VCD format, and since you only have 50 Min. this should be easy to fit. What is the filesize when you finish encoding it with TMPGEnc? What is the orginal file size?
Ethernet (n): something used to catch the etherbunny -
Some codec flips the video during the reencoding. 50 min should fit a CD as VCD no problem.
This is the fundamental problem with this kind of one click solutions - you are unaware of any problems that occur during the process, until you pop the CD into the player.
In the case of Nero, the mpeg1 encoder is pretty low quality too, so I'd suggest going the full circle of (VirtualDub->)TMPGEnc->VCDEasy(->Nero, if necessary)
/Mats -
Originally Posted by Roundabout
. Thanks for the help guys I found the problem. I tried previewing the file and found out that for some reason when the video ended it kept going on at the same frame for an extraordinary amount of time. That was why the file was so long. I guess it was encoded badly.
Wow, I guess it was ripped/encoded badly! You'll have to use an editor to cut out all the extra frames. Glad we could help out!
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 06:14 -
Problem with nero. I think!
By breeze9 in forum Video ConversionReplies: 3Last Post: 9th Jun 2008, 11:40 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 10:54 -
Nero Problem
By alley04 in forum Authoring (VCD/SVCD)Replies: 3Last Post: 6th Sep 2007, 18:08 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 17:36
