Before i get to the problem i think i should tell you how my project looks like:
The DVD i'm making contains 7 episodes of He-Man (2002) with German and English Audio.
It has only 2 menus for episode selection (German/English).
The buttons in the German menu are connected directly to the Movies, and the buttons in the English Menu are connected to the command sequences which were necessary cause i wanted to skip last chapter of the english audio which is shorter than german because of the moral lesson at the end.
OK, i've got everything to work as intended....but when i start any English episode (Playlist/Comm. Sequence) and when i press "previous" button on the remote, it alwasy takes me back to the German Menu when it should take me to the English one. Is there a way to avoid that?
I don't see an option in Connections window which will let me assign "previous" button for Command Sequences or Playlist. The Menu key is set to go to the English Menu but it also leads to the German.
Thank You
No it's not. At least i haven't found it on any of the 688 pages.
There should be an option to set which menu every button, command, or end action takes. You have two menus, just set commands to the one you want. That might mean going down the entire commands list but it's the only way sometimes.
The manual is pretty useless except as an over view of features I found. -
Thank you for the reply, and here are some screenshots i made from the Connections Window.
This one shows connections for one German episode.
And this one shows connections for the English Playlist:
Now, where is the option to assign "previous" button on the playlist. I tought it's enough to set Menu Key but it is not, and it also gets me back to the wrong menu.
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 10th Jun 2014, 23:23 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
DVD Architect pro 5: problem with playlist, brancing and next (skip) button
By alfini in forum Authoring (DVD)Replies: 0Last Post: 25th Oct 2010, 06:28 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
Media Player CLASSIC PlayList Problem
By pitsikoko in forum Software PlayingReplies: 10Last Post: 11th Apr 2008, 13:11
