A general computer question. Is there anyway to download the guides or posts and keep the images intact? It's easy to right click and "save target as" for the text and save jpegs seperetly but is there a way to save them as they apear online? It would be very usefull to have them on file instead of needing to log on.
Simple - go to the top of your screen, File - Save As and save the entire web page complete (just select where you want to save it on your HD). It will save a HTML link i.e. "DVDrhelp guide.html" along with a folder with the name of the page, i.e. "DVDrhelp guide files". The name on the folder will be the same as the Webpage link you saved except it has the word "files" at the end. Make sure if you move the link somewhere else, that you move the folder along with it, or you won't get the graphics, etc. - you would only see the text. The "files" folder must be in the same folder as the link or it won't work properly. You can create a new folder and name it, for example, TMPGEnc guide. Put the HTML link in the folder, then put the "Files" folder inside it also, as a subfolder. That should do what you are looking for.
Ethernet (n): something used to catch the etherbunny -
Thanks Roundabout. No one I ever asked knew that. However the only way I could get it to work is from the printer friendly page, which is better anyway.
Fit2Disc Guides
By montgal in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2009, 13:18 -
Virtualdub Guides?
By ATLien in forum Video ConversionReplies: 6Last Post: 23rd May 2009, 23:18 -
Looking for free HTTPS Downloading Manager for downloading video or file
By coody in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Feb 2009, 14:40 -
FAVC guides?
By php111 in forum User guidesReplies: 64Last Post: 25th Aug 2007, 11:53 -
question about one of the guides
By php111 in forum Off topicReplies: 1Last Post: 8th Aug 2007, 11:31
