  1. When I encode from avs file, CCE display the error message:
    couldn't file appropirate video Codec for 'YV12' . But when encoding directly from avi, there's no problem. I have AVIsynth 2.5 and ffvfw installed.
    Can someone help me to fix this?
    Thanks.
    Australia
    The cause is a little puzzling, but make sure that you don't have a line in the script that says 'ConvertToYV12()'.
    If you don't and you still get the error then try inserting the line,
    'ConvertToYUY2()'.
