hello . ive down some home made movies encoded them with tmpenc ,so i can put them on dvd. done some yesterday which played fine on w media player , encoded some today which encoded right way up on tmpgenc ,went to watch them on w media player found they r playing upside down. but ones i did yesterday which was fine r now playing upside down please help someone
they play fine on sonic dvd. but can i still burn them onto dvd? using dvd labs. if i do will they play upside down in dvd player
only had xvid codec ,now took off and has made no differance. wedding mpg film so um panicing here could it be a bug in windows media player can anyone help please
I also had this problem before, but it wasn't with mpeg movies per say. It was with quicktime *.mov files and then migratted to *.avi videos. The picture would display upside down when it was min in wmp. When I full screen'd it then it play'd right side up for 5 secs.. or so and then flip'd on me again.
I uninstalled QT 6.0 and installed WinDVD and it correctted the problem for me.
It should play right side up in your dvd player though. They use there own set of codecs to play videos.
bluewolfIF YOU CAN READ THIS THEN YOU THEN YOUR EYES ARE DAMN GOOD! PLEASE, LET ME KNOW, BECAUSE I AM IMPRESTTED WITH YOUR GREAT VISION. LOL. BY THE WAY PEOPLE SUCK. EVERYONE SUCKS.
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 13:52 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 16:47 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 20:23 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 09:09 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 03:36
