Hi!
I exported a video i edited with premiere into mpeg,
it gave me 2 files:
.mpa & .m2v
mpa has the audio & m2v has video...
how can i merge them [without loosing quality or reEncoding...]?
You need to author the DVD (or SVCD/CVD) look to the left under Author. Basically MPEG2 files are multiplexed files containing several elementary streams: Video (m2v), audio (ac3, mp2, PCM), and subtitles.
The authoring program combines all of the elementary streams into the correct file structure. For DVDs that VOB and IFO files.
MPA to AC3
By Benjy in forum AudioReplies: 6Last Post: 14th Jun 2011, 07:52 -
How to compress mpa stream
By jeby1980 in forum AudioReplies: 2Last Post: 23rd Feb 2010, 18:01 -
Convert ac3 to mpa
By pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 13:39 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
Mpa to ac3 5.1
By garherd in forum AudioReplies: 6Last Post: 3rd Sep 2007, 19:43
