I have a DivX file downloaded that is very much out of sync, I mean the audio has got to be about 20 seconds behind the video.
How can I fix this using VirtualDub?
Is it possible or do I have to use another application?
Thanks in advance!
Yours,
Beev -
Also,
How do I use the LogoAway filter? I cant find it anywhere?
Thanks in advance.Yours,
Beev -
you can adjust the audio under audio interleave in Vdub. For a decent explanation of Virtualdub procedures, try going to www.doom9.org then click on 'guides' then 'virtualdub procedures'.
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 02:03 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 18:47 -
Fixing Slow and out of sync .mkv file/video
By vanleeuwen in forum Blu-ray RippingReplies: 2Last Post: 18th Dec 2008, 08:26 -
Fixing sync problem on rmvb
By gameroftheuk in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2008, 22:16 -
Vdub audio filters causing problem on video track
By SearchQuality in forum AudioReplies: 4Last Post: 10th Feb 2008, 12:42
