To all you gurus that use stickers on their DVD's? Does this pose a problem during playback? My brother in law is putting stickers on his DVD's and say that when he puts his stickers on, it causes the dvd to skip and hvae problems and his theory is that it adds too much weight to the DVD, which is the reason why. I think it may just be the disc compatibility issue. any comments welcomed. Thanks...
Results 1 to 20 of 20
It's possible. Do a forum search on this topic and you'll find many threads relating to labels and their affects on DVDs.
Sometimes the affects of the labels are not immediate, but after some time they can show themselves. -
True, I used to put proper DVD labels on, with minimal ink, and had problems with skipping/pausing, so had to remove the labels
Shame really, they looked quite good with labels, instead of just handwritten titles
Also, media can make a difference as well, some machines don't like certain media, other will play anything
My machine refuses to play Mirror media at x4, but plays at x2... strange but true
But, I've used Princo, which a lot hate, and at x4 plays pretty well -
Labels are bad because they cause an imbalance and changes the throw distance between the laser and the disc itself. A change in the throw distance cause the laser not to be in focus creating a skip or a slow motion effect. I write my titles onto the disc itself using a special pen made by Hama. It looked ugly at first because I have ugly writing but my wife has excellent handwriting so she now writes the titles.
When all else fails, buy an apex dvd player. -
Thanks for all replies....is there any dvd labelers that is light enough to work without problems? any recommendations?
Personally I think you guys are full of shit. Can you REALLY prove lables cause the DVD to skip? Don't think so....99.999999999% of the time its your media, or player, or burner, or your process, NOT a damn label. My 2 cents.
Live Long, Play Hard, Think BIG! -
Watch your mouth. I still use the same media but changed the labels to hub labels. My playback problems went away. So for me it was my labels.
Hello. -
Then there's CD printers. Never heard of any problems with them.
"Art is making something out of nothing and selling it." - Frank Zappa -
can you prove it ain't, I doubt it but you can quite easily prove it is the lablesOriginally Posted by kpoman
people who have stuck labels on and the DVD hasn't played then rip the label off and the DVD plays faultlessly. I think that's proof enough don't you?
so next think I'd think carefully before letting your mouth go as I don't think the guys are full of shit -
Use Hub labels.
They are cheapest per label (520 for 10.00) and only cover the clear plastic in the center of the disk
Granted the text and logos are small, but its clean and about as safe as you can get.
8) -
Now where have I heard that before? You tell 'em, Jntaylor63!Use Hub labels.
Hello. -
Studies do show that labels on DVDs can cause issues.
http://cd-dvd-supplies.com has special "no wobble" labels that claim to reduce the problem.
The 2 issues with these labels that I have found are: 1: that they are clear, so you need to use DVD Media that has no factory print on the disk. Best to use "White Top" media. 2: they are expensive @ US$34.00/100.
Details: Stock # 313758 or 313792 (Stomper or Avery Compatible)
Helps Prevent DVD Playback Errors & Jitter
Minimizes CD-R High-Speed Playback Errors
Especially recommended for ALL recordable DVD discs!
Ultra-thin permanent labels - will not wobble or peel off!
Our bulk clear CD/DVD Inkjet Label Refills. Special ultra-thin clear inkjet printable composite polymer inkjet labels will adhere permanently to discs, preventing the curled edges and playback wobbling errors you could experience with older, thicker labels. These improved thinner labels also minimize possible high-speed CD-R playback problems that are caused by old-style thicker labels being applied even slightly off-center.
Especially helpful with recordable DVD-R, DVD-RW, DVD+R and DVD+RW discs, where even the slightest off-center regular-thickness DVD label can make the final recorded DVD unplayable or cause a blinky, jittery video quality during playback on some DVD players. Super absorbable, porous surface clear labeling material, especially formulated to work with high resolution color inkjet printers -- absorbs most inks without smearing (see recommendations below). These special light-weight, super-thin labels feature smaller 5/8" small center hole and optional peel-away larger 1-3/8" hole too, with a "full face" 4-7/16" larger diameter printing area. Use the smaller "full-face" style center holes with the new Avery Afterburner Label Applicator Tool, or the pop-out optional larger center hole if you are using the Stomper applicator tool. Labels are arranged 2-up on 8.5" by 11" sheets, in an Stomper compatible layout, pressure sensitive. They work with most inkjet or offset printers. Be sure to download our FREE label printing templates. Use these layouts as a guide to help you design and print your labels in your favorite graphics program, such as Adobe Photoshop, Illustrator, Freehand, Corel Draw, etc. (Click small product photo above for layout template.)
RECOMMENDATIONS -- These labels are made from a special polymer combination material that cannot withstand high heat from many laser printers, so they are recommended for inkjet printing ONLY. Be sure to use only with blank surface discs, without any brand or other imprinting. White topped discs are recommended if you're using full color designs. Silver topped discs can be used if you're only printing text in solid colors. Fast drying inks are required. Use printer settings for high-gloss, polished surfaces. Avoid using heavily saturated, multi-ink colors such as browns and purples when possible. If too much ink is applied, combining several colors from different cartridges, the thinner material will not be able to absorb the excess ink. A little experimentation with different color combinations can produce excellent image results.
Hope this helps. -
i have backed up about 10 different move onto a dvd+r memorex 4x disc. put labels on all of them, no problem except for one that had a little scratch on the disc. redone it put a label on it no problem now. labels for me works with no problems
"simi-ditto"Originally Posted by Tommyknocker
Never had a problem but why risk it. I also switched to hub labels just in case. I am WAY to anal for an ugly Sharpe to be used. I do believe it may be more of a DVD player problem than a label problem.(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Let's all agree to disagree. I think it could be all of the things discussed. From my personal experience I have been burning dvd-r for over a year now with set top panasonic and pioneer/cendyne pc burner. I have been labeling them all the time too, full disk labels. Some of the discs have been for my soon to be 4 year old daughter. Needless to say some of those dvd's get quite a workout. Have been played numerous times on the panasonic, the pc, and an apex 703a. No problems. I think sometimes it's a disc quality issue, sometimes a hardware issue, and sometimes an issue with the method of labeling. I have used 2 labeling systems, a Fellowes/Neato one ( label goes face down on holder, disc on top of spring loaded mechanism ), you press it down and it sticks. The other is a TDK system, plastic clamshell put disc on one side label on the other and close to seal. As long as the labels hub holes match the applicator hub, the labels seem to be centered very good. If I attempt to use labels that are bigger than the hub, they could get off center and could case the disc to be unbalanced. So, if you do use full labels, make sure they are centered and make sure the ink is dry before applying to disc. I had a few that I tried to apply when they were not dry and as I peeled them off the paper, they stretched from the ink.
I had the same problem using DVD/CD labels and they immediately caused the DVD's to skip/freeze during playback. Since I couldn't easily remove the label, I ended up burning new copies and they play perfectly. I now use a sharpie to label the DVD and use the thin CD cases and print a cover to insert into the case. This works great.
I have been using the Casio CDR-50 title printer religiously on both CD's and DVD's for the last six months. It produces a good looking and non-raised surface with its thermal head. Works on both silver tops and white tops. Does not require special inkjet ready disks and it does not unbalance or damage the disk. The printer goes for $85 and the ribbons go for ~$6 (50-60 prints). Though it only prints one color at a time, you can vary the ribbons (black,blue,red,silver,gold) to create a multicolor effect. However, I prefer the black overall and they also last the longest.
It is too bad that Casio didn't use the same method that Alps used for its printers. Then the machine would change ribbons by itself. Too bad Alps is no longer, those printers did have a great photo output. Nearly as good as dye sublimation printers.Originally Posted by jzaman
Also the inkjet disk printing is beginning to take hold. With Epson making 2 home use printers, as well as the EZ/CD printers. Canon has a Japan market machine that will do disks, but they have the US model locked out from working. Must be a license or patent problem. You can also buy hacked printers that will work, but they are just as expensive as the Epsons. Then there is always making one yourself
(see below)
Now all we need to do is get the disk manufacturers all using the proper coatings for inkjet use and we will be all set! Memorex seems to be leading the consumer push for printable disks. They are the only "common" brand that has them available. Now if we can just get the walk in stores to stock them. You can buy them from the Epson store, among others, and the seem to work well. Drying time in 15 minutes or less. Just don't hold it in water!
When Epson sees their blunder, they will put disk printing in their pigment ink printers and all will be forgiven.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Conversion of .TS to .MPEG2 causing problems
By DirtyMetis in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2011, 12:10 -
ffmpegX flv causing problems with blip.tv player
By orionrush in forum ffmpegX general discussionReplies: 0Last Post: 17th Feb 2011, 18:55 -
Stickers on DVD
By Iwan2learn in forum Newbie / General discussionsReplies: 6Last Post: 13th May 2009, 07:52 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 14:59 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 03:41
