A friend lent me a DVD-R that was somehow created with a screwed up directory. It won't play on either of my component DVD players or my AGP G4 tower. My iBook was able to open it so I used DVDbackup to extract it. I transfered the VIDEO_TS folder to my tower and the .VOB files are fine and they play perfectly in VLC. This is probably a real basic question, but what is the best way to re-author this to a working DVD? Also, what is going to be the quickest and easiest way to do some basic editing of the .VOB files? The DVD consists of several musical performances that I would like to separate.
yes
1. demux the .vob's and you will get individual movie and audio files for each .vob
2. you can then reimage the dvd in working order with sizzle to make it playback normally
3. if you want to edit the movie, you now have individual movie and audio files and can edit accordingly -
What's your preference for demuxing .VOB files? bbDemux is quick, but gave me files that Sizzle said were not valid. It also created another file besides the .vob and .ac3 files. What are these and do I need them? Thanks for your (always) great advice.
honestly, thats what i use.
.m2v (mpeg2 video with no sound) and .ac3 (the sound corresponding to .m2v)
If you get anything different, which you shouldn't, unless its a strange audio type, just convert the audio
if you dont get .m2v i have no idea what you are getting.
acceptable audio for sizzle is essentially all types, .ac3 .mp2 LPCS and DTS
Zosma to the Rescue
By wulf109 in forum ComputerReplies: 0Last Post: 16th Oct 2011, 09:59 -
Question how to include software on authored DVD with Nero 6
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 1st Oct 2008, 12:13 -
Question about how to include software on authored DVD
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2008, 20:47 -
How can I rescue video from a DVD?
By OM2 in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2008, 14:46 -
How can I rip a badly made DVD?
By semmel in forum DVD RippingReplies: 6Last Post: 14th Jul 2007, 11:34
