Using Pinnacle Studio8 to create DVD movies from DV camcorder.
When I try to burn finished movies on my Plextor 504A to +R DVD's its gets part way through the burn and spits out disc saying burning complete. When viewed on standalone or PC player disc is not detected.![]()
Burning of +RW's are OK.![]()
Does the file play correctly ? if studio8 says its finished maybe you should believe it? or try burning same file with nero 6
media compatibility?
burner error?
Ahhhh 400 what a relief...Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Vegas movie studio 11 -- need to burn AVCHD file to DVD
By malcolm1 in forum Newbie / General discussionsReplies: 14Last Post: 8th Nov 2011, 02:12 -
How to burn FCP cut using DVD Studio Pro4?
By dvdude in forum MacReplies: 4Last Post: 8th Mar 2008, 22:12 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
