I'm using a Pentium 4 1.3 GHZ processor with 256 MB ram, and a fast hard drive. I only get about 1.5 FPS while encoding. Other encoders, such as flash mpeg or TMPGENC give me around 15 FPS. Is this normal for DVDx? If I were to use a plugin with it, would it speed up? Any help would be appreciated.
Thanks!
Mikecito
~~~Kinda new to this~~~ -
Yes I get about the same with my Duron 800.
DVDx rips the audio and video at the same time while Flask does them seperately. This may be why there is a F/P/S difference.
Have you had any problem when burning the file? Do you use Nero?
I can burn the files fine, and the quality is absolutely amazing. The thing I can't understand is why it encodes so slowly. I use VCDImager in combo with Nero to make my menus/chapters on my SVCDs. I get about 35 min. of video on each cd, which isn't very much, but the quality is way worth it.
I'll try a plugin or something and see if that helps.
Thanks for the reply.
Mikecito
Can you help me with chapters on VCD?
I have tried VCDimager and TSCV but with no success?
I think VCDimager looks easyer but it burns and play fine but no chapters?
What settings do you use?
I use chapters, but no menus. You can use TSCV to do this. I don't like menus because the SVCDS I make only have 35 min. of video on each one anyway, so I divide it into 4 minute chunks using chapters. The guides on this site helped me out a lot. Check under the Author section under SVCDS with chapters. It has a lot that will help you out. Also, it might be that your DVD player just doesn't support chapters. I use the Pioneer 434. It works great with everything I've thrown at it.
Mikecito
Kinda n00b with ripping - kids ruining DVDs!
By pizzaguy4hire in forum DVD RippingReplies: 7Last Post: 11th Jan 2012, 20:58 -
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
Cable TV with 2 way splitter To 2 Tvs Singal Is kinda Bad Need Help
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2009, 20:57 -
HTPC .. well kinda!!
By Lucifers_Ghost in forum Media Center PC / MediaCentersReplies: 10Last Post: 21st Jul 2008, 18:02 -
New Pc - Videos are kinda Blurry
By stupidhead64 in forum Newbie / General discussionsReplies: 4Last Post: 9th Oct 2007, 11:49
