I have found that using ASF tools to convert ASF files to AVI files I can get the resulting AVI to play (AND ONLY PLAY) in TMPGEnc. Where I turn them in to VCD complient MPEG's
But, that only works for the video, there is no audio.![]()
While on page 2 of the Wizzard the video file appears, the line for the Audio file is empty.
Is there a way to also play/convert ASF files with both audio and video
I have tried playing either the orginal ASF or coverted AVI file other applications, but, all I get the "cause fault window."![]()
I dont know if this works or not...but I remember someone suggesting this once. Go to Windows Movie Maker, open the file there, and then save it as WMV and then encode. Again, dont know for sure.
>I've used ASFTools to convert video files, and its done the audio no problems
I will try that
FYI, I tried EO Video, which has been mention in this forum, to convert ASF to AVI/MPEG
While it save some steps, I still get a video with-out audio.
Could it be that the video (Mexican commericals about the end of the orginal VW Bug) have no audio.
I am going to try to get a ASF file with audio to see if that is the case.
Will report back . -
I use Music Match Jukebox 8.0 to play .asf files, not that I get many, but it plays them. Just a point??
you say Y,
I say Y not? -
The problem in getting both the video and audio to play from a ASF file has been answerd
I downloaded another ASF file, and using EO VIDEO, I got it to play ASF files with both audio AND Video
And covert/merge them into one MPEG 1 file.
However, the resulting production is very "blockly."
Is that a usual problem with ASF files
Or (I used VCD bitrate/size/frame numbers) did the conversion went wrong
Yet, to be honest, even the non converted ASF file was not all that clear
ASF to DVD - Question about freeware
By Golem in forum Video ConversionReplies: 0Last Post: 20th Mar 2010, 10:16 -
asf to vc-1
By sampalmer21 in forum Video ConversionReplies: 1Last Post: 16th Dec 2009, 14:27 -
vc-1 to asf
By sampalmer21 in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 19:47 -
ASF to AVI
By Arizona42 in forum Video ConversionReplies: 1Last Post: 31st Aug 2008, 23:20 -
AVI to asf ?
By rindless in forum Portable VideoReplies: 38Last Post: 26th Jun 2007, 09:15
