Hello, i have a problem, i have a divx film but the Audio is to quiet, does it give a tool, to make it louder?When yes can you tell what i must doch please.thx for help
Only way I know, as the soundtrack is part of DivX, is to extract the audio track, run it through a util to normalize the volume (boost) then re-encode it back to a DivX, if you specifically want it in that format
Best program I've used is one called dbPowerAmp, with the PowerTools
Basically it has a few DSP effects, a very interesting normalize tool that just doesn't boost overall volume, but works out the quiet parts and the loud parts and boosts when needs boosting, but leaves the rest alone, without clipping or blasting your ears
I use it on all my audio tracks, before burning to DVD, no matter how abismally quiet the audio is (and some have been terrible), this will bring it back upto an acceptable level without distortion or making the quietier parts 'hissy' as other normalize programs tend to do
How to make the audio louder in an H264/AAC video
By rumplestiltskin in forum MacReplies: 17Last Post: 29th Jun 2011, 22:17 -
I want to make the Audio in some AVI files louder
By Simmons in forum AudioReplies: 10Last Post: 26th Dec 2010, 11:22 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57 -
Making audio louder in Virtualdub
By BobAchgill in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2009, 19:13 -
how to make the audio of DVD karaoke louder
By edong in forum Authoring (DVD)Replies: 2Last Post: 20th Oct 2007, 16:23
