I have A MPG2 file its 6.12 GB.How to make this smaller to put on my external hard drive.
Results 1 to 12 of 12
Why are you not able to transfer it to your external hard drive with it being 6.12GB?
SLICK RICKOriginally Posted by lordsmurf -
I don't know I have pleny of room but it says the file is to large.I got a 80gig hard drive.Can I make this file smaller.
If it is FAT32 it can not handle anything more than 4GB.
How did you get the MPEG-2 file? Did you encode it from another source?
Originally Posted by CORRY20
If you want files that are bigger than 4Gb, you need to format the drive with an NTFS file system, it has no limit on file size.
As for your second question, reencode the file with a lower bit rate.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
All you have to do is what housepig said "reencode the file with a lower bit rate."
Corry20 - you really need to provide more info when you post these things. It also helps if you fill out your profile so people know what kind of system your running. Background info about: where you go the file, what you want to do with the file, and your final goal with the file, etc. is always helpful.
So you captured the file from a VHS tape (appearantly directly to MPEG) on a system that's formated for NTSC. But you have an ext HD that you want to transfer it to.
Unless you're running an OS from that ext HD, just reformat it for NTFS (you can try to upgrade to NTFS but several people have problems with that). Based on the (little bit of) info you posted that should work without having to re-encode/capture your MPEG fileGood luck...
mpg2 color correction?
By Mike99 in forum RestorationReplies: 74Last Post: 25th Oct 2011, 22:31 -
Editing MPG2
By danielmak in forum MacReplies: 16Last Post: 17th Feb 2010, 17:28 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 17:33
