I get a error massage every time I use the Movie factory, anyone come across this or knows what could be wrong?
Results 1 to 10 of 10
It would help some if you would supply some details of
what you are trying to do with what files -
I started with a xvid .avi file and want to get it on a DVD. I have extracted the sound then used TMPGEnc to make an mpg file then tried to author it in Movie factory and burn it on the DVD. All fine until I get to the Movie factory file it comes up with an error some where near the end of authoring. I have checked the file and found to be OK.
Is there an easier way getting form xvid to DVD? -
I suupose there is no way to find out what that error is from Ulead ?
Probably not. try anyway -
It just occurred to me that MF2 appears to be trying to CONVERT the file.
Why would it do that if its already compliant ?
What are the encoding settings ?
720 x 480 MPEG2 4000 kbps MP2 audio 48000 s/s ?
Have you set "do not convert compliant files" ?
How long does it take to get the error ? -
What are the exact properties of the MPEG file?Originally Posted by atashy
For example, my Panasonic MPEG files have the following specific properties:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 704 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Variable (Max. 8800 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 48 KHz, Stereo
How do the properties of your SOURCE MPEG compare?
Jerry Jones
http://www.jonesgroup.net -
I just noticed Ulead has posted a new update patch at the following link...
http://www.ulead.com/tech/dmf/dmf_ftp.htm
It's a free download.
Hope this helps,
Jerry Jones
Gee Jerry just noticed I said some about this days ago on ulead forum jerry
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 21:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 22:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
