can someone help??
trying to covert xvid 2 dvd
file 25fps-48000mz
used goldwave to convert ac3 to wav i now have seprate wav file
i used avi codec to check that i have right codecs which i have
i set tmpeg enviromental settings as instucted.
and i still cant ad main file to tmpeg comes up can not open or unsupported.
even if i could split ac3 from vidio would it work and how?
any ideas
You can separate the video using virtual dub. Load the avi in virtual dub then choose audio>no audio. Then video>direct stream copy. Then file>save as avi. This will five you an avi with no audio. Use this and your wav file in TMPG. How are the priorities set in the environmental settings? What instructions did you use?
used help on dvdrhelp for settings.
enviremental settings are direct show 2 above everything else.il try the advice now and report back. -
virt dub will not acpept file!!
(could not locate decompressor for format xvid unknown)
virtuall dub reqs a video for windows (vfw)compatable codec to decompress video.
i already downloaded xvid codec and installed so i can watch on bsplayer which i can -
Open up virtual dub and choose video>full process mode. Then under choose video>compression. A new window will pop up listing the codecs available for compressing. Scroll to the bottom and make sure you see te xvid mpeg4 codec. If not try installing it again. If it is there, the only other suggestion I can make is to download the avi fourcc code changer from the tools section under codecs. Load your film into it and change the fourcc handle from xvid to divx. There should be instructions on how to use it with the package when you download it.
i sorted it i have xvid codec by nick download koepi version and it works fine now thanks for the help.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
Prob using DVD Flick
By Tbag in forum ComputerReplies: 2Last Post: 11th Oct 2008, 17:00 -
Small prob with DVD Flick
By Tool Man in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2007, 07:29 -
sound prob on dvd from mkv
By umpaflumpa in forum Video ConversionReplies: 2Last Post: 20th Dec 2007, 12:02
