hi,
i'm wondering if anyone can tell me how I can burn a avi file that I have to a VCD so I can watch it on my DVD player. I have looked at some guides on this site but I can't find which is the right guide I need to use. When I burn my avi file to a VCD I want it so that when I watch it on TV it fills up most of the screen.
If anyone knows how I can do this then please let me know.
thanks,
Jonathan Cooper
Read the how to convert on the left side,it explains all you need to know
Okay you go to the Capture section to find the right guide for capturing in AVI. Then go to the Convert section, and find your guide to convert AVI to VCD MPEG. Finally, go to Author and find your guide to make and burn your VCD to disk.
Of course, there are some trialware that can do all of this a few steps. One, like Video Studio, lets you capture, edit, and burn all in the same program. Hope this helps.Hello. -
will https://www.videohelp.com/forum/userguides/111846.php be the right one I need to use?
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Burn an AVI file on a DVD - Best software to do this
By tim_ver in forum Newbie / General discussionsReplies: 11Last Post: 26th Sep 2008, 13:51 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 21:30 -
Author and Burn AVI file with subs
By Squid_uk in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2007, 06:12 -
Burn AVI file to DVD disk
By clms in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2007, 14:10
