I just finished creating my first dvd mpeg using svcd2dvdmpg 1.1 and it looks like there are these jagged edges on everything. Is this what I can expect? It seems like a great program except for the fact that the quality of the svcd isn't replicated exactly.
Results 1 to 17 of 17
Guest
make sure you do a 2 pass encode and do not tick skip resample step.
ive had no probs with svcds.
regards phil -
What are you doing? creating ES or PS? Are you patching /repatching? If so to what value? How are you authoring?
I'm doing MPG -> ES and my horizontal res patch is set to 720. That's pretty much it. Oh my source file is an svcd.
well if you patch files to 720 then you will not see the true result until you patch back to 480 after creating your dvd folders via your authoring software.
It might have not been clear on the website but if you patch sequence headers to fool the DVD authoring software then you need to patch the headers back to 480 post authoring. (the intermediate ES or PS files from SVCD2DVDMPG will always be "weird"). So to do this you author the ES files. Produce a VIDEO_TS folder with VOBS etc in there. Now start up SVCD2DVDMPG, browse to the VIDEO_TS folder, choose ES or PS (in order to enable the patching section), click 480. Now click start and the VOBS will be patched back to 480. (choice of first header/entire file is dependant on what you did when you patched to 352 & whether your authoring application produces a VOB per mpg or not)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
what do you authoring with?
I realize that but the quality of the mpegs aren't coming out the way they're supposed to. Edges are jagged looking.
It looks fine on my computer but not on my ps2. It's definately not the source.
are they vcds or svcds?
Mmm - it is know that VCDs (mpeg 1) are crap on PS2....
I don't know for sure but it might be that your player only supports vcd-dvd which means it will only except exact VCD (not XVCD) on a DVD to play as VCD.
Greatings,
Yf
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 08:44 -
playing mpegs on a dvd player
By fromunda kid in forum Video ConversionReplies: 8Last Post: 9th Mar 2008, 13:30 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 03:01 -
HELP: Looking for a GOOD DVD VHS combo - Don't need to record just play...
By UNOWEN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Sep 2007, 12:24 -
how do I compress DV videos into good quality mpegs?
By bball_1523 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 1st Jul 2007, 17:22
