Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Just for kicks you might try ForceASPI drivers but I think it's your media.
  2. i know nothing about the brands i only thought + and - mattered
    how do i do a firmware update? ill look arond the site but i prob will get lost so a link would be help full
  3. i did the force drivers and it didnt do anything but make windows tell me that i replaced new drivers wither older ones
    how i fix dat?
  4. Originally Posted by BlasterPQ
    Original here:
    http://forum.rpc1.org/dl_firmware.php?download_id=1517
    Regionfree here:
    http://etna.rpc1.org/nec/index.html
    Flashing is dangerous read everything carefully
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    @BlasterPQ, why not try Record Now trial to see if you get the same results?
    Nero may not be setup properly or maybe something is conflicting on your system so unistall it and install RNM and give that a bash
    try a simulation burn also and see if that works before burning another disc
  6. thanx but what ver do i need on that firmware?
    im goin to do firm ware fist then if that dont work ill jump off a bridge and if i make it back top shore ill try that burning program:-p j/p ill try it after firmware
  7. any one know what ver of the firmware i need?
  8. i downloaded ver 1.07
    now i have few reed me questions
    The Reedme states:
    (1) -this Update works only with NEC ND-1300A (retail&bulk), not with OEM releases.
    (2) -deinstall (if installed) your Packetwriting Softwares (f.e. InCD or directCD).
    1. how do i tell if mine is the bulk or OEM ver? im pretty sure its not retail since i got it in an anti-static bag
    2. i dont think i have those 2 programs but i nero one? can some one list some more common ones?
  9. i did the firm ware i burned the iso and it works like a charm
    props to everyone that helped
    i think i make a tut on the method i used to copy my dvd
    wink wink
    -Blaster
