when I try to rip a specific DVD , after a while it says " i/o error " and stops working, whether i use dvd shrink or dvd decrypter.
with other disks, it works all right .
Any idea about what to do???
Well, something to do with that disk.
Look at the recording (data) surface. Visually check for dirt or scratches.
If it's dirty, clean it. If it is scratched, clean it again - it helps. Minor scratches can be corrected. Major ones cannot.
Also, with DVDDecrypter, you can go to options and increase the number of bad reads before it aborts. Usually it is able to recover - unless the disk is too damaged.
Having DVDs die on us is why we back-them up.
The more I learn, the more I come to realize how little it is I know.
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 17:43 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 11:50 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 11:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
