  1. I am trying to write these dvd+rs that i have onto my computer as iso files. I try using DVD Decrypter and at 88% it fails every time b/c of bad sectors. The DVD works perfectly in a dvd player. Does anyone know why this is and how to get around it?
    Thanks,
    Adam
    Mar 2003
    Uranus
    Did you clean its little bottom ?
    Sep 2003
    Greece
    DVD might be scratched or dirty!
    You can start by cleaning it with a soft cloth and giving it another go. If the errors aren't too many, maybe you'll end up with a working backup!
    Remember to set DVDdecrypter to ignore read errors.
    If cleaning the DVD fails, then most likely you have a damaged/scratched DVD. You could give it a go with IsoBuster in order to obtain an image. Be prepared to wait for a long time to rip though...
    I remember spending two days trying to backup a DVD-9 that my girlfriend at the time used as a coaster! I got some 750 read errors and although i managed to get an image of the disk i waz unable to further process it!!
    No need to tell you i was finally forced to buy a new copy of the DVD (dumped the careless girlfriend after a month too!! My scratched original DVD of T2 was the final straw!!! ).
    Sometimes ya just have to give it up backing up certain disks...
    Hope this helps
    LeoNapier
    The Truth Is Out There - X Files
