Results 1 to 9 of 9
  1. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    I'm saving my emails in a seperate folder in dbx format. At the moment I read them with "MAILNAVIGATOR" but this is a shareware. Does anyone know of a good free program? Thanks
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  2. Member holistic's Avatar
    May 2001
    here & there
    Outlook Express will read *.dbx (it makes them) If of course that program you were using uses the same format.
    Good Hmmmmmm : NO - Free : Yes
    Do a search using *.dbx to find where the files are stored. (If using IE you most likely have a copy of Outlook Express on your computer)
  3. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    Try this one, freeware, if it meets your needs - "DBXtract"
    http://www.oehelp.com/DBXtract/Default.aspx
    Ethernet (n): something used to catch the etherbunny
  4. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Holistic........I'm saving my emails from Outlook express in a seperate folder (not in O.E.) then whenever I need to search for an old email I launch MAILNAVIGATOR which can read the dbx files. I'm not sure it would be easy to dump them all back in O.E to do a search. MAILNAVIGATOR does a good job, but when the 30 days run out I have to buy ( and my Aussie dollar is not like the US$ ) so I am looking for something else.
    ROUNDABOUT.......I have looked at dbxtract and can't figure it out.
  5. Member holistic's Avatar
    May 2001
    here & there
    Noted ..
  6. Yes, I Know Roundabout's Avatar
    Jul 2003
    Here's another one you can take a look at: http://uruds.gateway.bg/zeos/
    Look toward the bottom of the page for the MS DBX reader v.1.2 .zip - maybe this one will be more to your liking. It's free, one of your requisites. Hope this helps.
  7. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Thanx, I have got DBXTRACT working now and it's just what I'm looking for, thank you again for that info.
  8. Yes, I Know Roundabout's Avatar
    Jul 2003
    Great, glad that helped. It didn't look too complicated when I checked it out, on the other hand I didn't try to use it, either! 8)
  9. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    The problem I had with it was because I had the setting "compact folders in background" ticked. After I unticked it I found it worked ok.
