Using a Micro Advantage DVD+-RW. I can author a dvd movie and burn it to a +rw and it plays fine in 2 different players. When I burn the same dvd movie to a +R it wont play. +RW are Phillips and +R are TDK. Any solutions? Bad media? I checked and both players are compatible...arghh
Results 1 to 19 of 19
You could be using the wrong book type. I had the same problem you're expereincing on my Memorex (Ricoh) until I corrected the Compatability settings. This link may help:
http://www.dvdplusrw.org/resources/bitsettings.html
If you use Nero, make sure that "DVD-ROM" is ticked before you burn. -
That setting is for data. See this thread, near the bottom, for suggested settings:
https://www.videohelp.com/forum/viewtopic.php?t=179049&highlight= -
SIMES, Sony drives dont support bitsetting at the moment
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I also use Nero. Here is a direct link to the settings I suggested:
https://www.videohelp.com/forum/viewtopic.php?p=653845&highlight=normal+following+set#653845 -
Interesting burning software that lets you go without finalizing a DVD-Video.
Hey vegasdude!
What kinda thing is this Micro Advantage drive?
Rebadged by who? Whats its firmware? Buffersize?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Richard!Originally Posted by richard98
Only Ricoh type burners and the latest BenQ support bitsetting at the moment.
Your Memorex is one of them (oem Ricoh5125)!
Other drives firmwares just do not support it. Believe me!You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Tom...Unable to determine...sticker on the drive say Micro Adv, Frimware 0038 and 2mb buffer....I'm gonna try -R tonight....
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
Some DVD works, some other don't
By boraborasands in forum Authoring (DVD)Replies: 3Last Post: 18th Dec 2010, 11:06 -
One SRT works, the others don't
By ebay in forum SubtitleReplies: 1Last Post: 24th Jun 2010, 16:48 -
TMPGEnc DVD Authoring Works 4 DVD+r space problem
By gigaslackr in forum Authoring (DVD)Replies: 1Last Post: 28th Dec 2009, 14:43 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 23:22
