Hi
I have a Pioneer DV-535 DVD player. I am making home videos on DVD-R. When I do this my settings VBR 6000 kbs, 720*576, 25 f/s, 48000Hz 224 b/sec audio, which are the standard settings for PAL DVD. The DVD-R (TDK) is 1.5 hrs long. Burner: Pioneer A04, burning at the slowes speed to avoid compatibilty problems. After watching the DVD for an hour without a problem it starts getting all blocky and freezes. Tried the same DVD on different players have faced the same problem on some, on different time segments of the video. I edit with Ulead Video Studio 7.0 and burn with their software.
Is this a software problem or is it because some DVD players are more sensitive to VBR. But then if you make DVDs with CBR the space won't be enough on the DVD-R.
Thank you in advance for any feedback
Sonat Schulz
It's the software or authoring process your using. All retail DVD's are VBR and they play on your DVD,don't they?
Yes retail DVDs do play without a problem.
I have just done a CBR version of the same video, and burnt with Ulead software, this one worked fine on the Pioneer. It's quite weird.
I have just started doing freelance editing for home videos. THinking that everybody has different types of DVD players I am trying to set a standard for the DVDs I will produce for my customers. VBR is scaring me as it can cause incompatibilities. Should I go for VBR DVD-Rs or am I wrong here?
Thank you so much for taking time in answering
Sonat Schulz -
It might be a daft suggestion, that may have already occured to you, have you tried different media? - Try a nice Ritek
Your reports match, exactly the problem most of us have when using iffy media.
My Pioneer player (737) does not like bad media - most drop-outs start around the 1 hour mark and get worse towards the outside of the disc (if the disc plays that long).
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
DVD Player crashes when playing dvd with vietnamese subtitle
By ssalim in forum SubtitleReplies: 0Last Post: 28th Apr 2010, 16:52 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35 -
dvd player vs dvd recorder for playing back dvds
By JCWagener in forum Newbie / General discussionsReplies: 5Last Post: 14th Mar 2008, 17:50 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37
