Hi. I can play Dolby Digital trailers using mplayer2, WinDVD, PowerDVD. When I play with mplayer2, it uses CyberLink's codec to play sound. But when I play two of the DTS trailers (the first one is actually Dolby Digital) using mplayer, it doesn't play sound at all. I know I can use WinDVD or PowerDVD but is there anyway to config mplayer to use CyberLink or InterVideo's codec to play the DTS sound? The trailers are from http://www.cinenow.com/us/vobtrailer.php3 . Thanks in advance.
a dts trailer in dolby digital ... crazy .. whats the point ..
and the answer i believe is no .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How to use MPlayer to view BluRay Movies?
By illogan in forum Software PlayingReplies: 2Last Post: 6th Feb 2011, 10:52 -
DTS Audio not recognized when I play movies from my extern HDD through PS3!
By Spdngblt56 in forum AudioReplies: 1Last Post: 8th May 2010, 17:51 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
Blu-ray or rip movies don't play in 5.1 surround sound. Help?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 15th Feb 2009, 16:07 -
Does removing DTS sound in movies help Dolby?
By JohnnyBob in forum AudioReplies: 22Last Post: 11th Sep 2007, 15:53
