I captured a video in Mpeg2 Good Quality using WinFast PVR. But Nero is saying that isn't in SVCD yet. So i went to tempgenc and tried to use the wizard but it keeps saying error cant read file type...
So then i tried MPEG TOOLS and it loaded in that. Then i made it into MPEG-2 Super VideoCD (VBR)
what should i do?
Thx
Results 1 to 22 of 22
if its in SVCD specs, burn it, try VCDEasy.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
DVD:
Capture:
SVCD 480x480
CVD 352x480
VCD 352x240
Video Stream: Motion Video, 320x480, 29.97003fps (NTSC), 4000kbpsEjoc's CVD Page:
DVD:
Capture:
you can use DVD2AVI to frameserve the mpeg to tmpgenc. In theory you can get TMPGEnc to read MPEG-2s but I've yet to see it work. If you want you can demux the audio from the mpeg you have now, that way you dont have to reencode it.
Hmm I recently upgraded TMPGEnc to the latest version, and now mine is reading MPEG-2s just fine(I just tried it out). If you cant get TMPGEnc to open it directly, use DVD2AVI to frameserve it.Ejoc's CVD Page:
DVD:
Capture:
i cant realy size it to much, if thats what you want me to do.Ejoc's CVD Page:
DVD:
Capture:
Its not the resize from 320->480 that will distort your picture much, its that you would be re-encoding MPEG2->MPEG2 (something you want to avoid) This is why I never capture in MPEG.
Ejoc's CVD Page:
DVD:
Capture:
Ok well now i did a little TV-out trick and recorded it onto a VHS. So now im going to capture that VHS in a uncompressed AVI. "i know i will lose some quailty this way,but i realy have no other choice"
Ok but now my WinFast PVR has alot of sizes to record from. What one should i use?
160x120
320x240
352x240
252x288
640x480
720x480
720x576
320x480
Which one do you recomend?
THX SO MUCH BY THE WAY -
If you are going to capture as an avi, use the huffyuv codec. Some capturing software VirtualDub is what I use, will let you enter custome capture sizes, hunt alittle and see if yours has that option. If not you could try VirtualDub out, or iuVCR. But if you cant get 480x480, Id capture larger and scale down, so I'd go with 640x480.
Ejoc's CVD Page:
DVD:
Capture:
Ok i got VirtualDub capurting it in uncompressed avi. And it wouldn't let me add in my own size. Probly somthing with it being a WDM driver.
so its in 640x480. I'll how this file works witn tempgenc in about 18 mins or so after its done capturing.
Thx again, i didn't even know u could record in Vdub. Its so much better then this winfast thing i was using before. -
Frameserve was suggested aways back, he didnt want to do it.
Ejoc's CVD Page:
DVD:
Capture:
That file was all messed up. The only program it could load is in Vdub. I dont realy know how to Frameserve, but i tried to resize but didn't have much luck.
Anyway i know i should of taped it on a VHS again, but it was the easyest thing i could think of. "Plus i had 2 hrs last night of doing nothing, so no big deal for me."
Anyway it all works now. Its fainly on a Svcd. This will be the last time i capture in an mpeg.
THX AGAIN for all your help.
Captured from BlackMagic Intensity Pro > convert to blu-ray
By necron99 in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2012, 02:14 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 21:01 -
A captured streaming flv video file being VERY difficult to convert.
By mgdt in forum Video ConversionReplies: 1Last Post: 21st Oct 2009, 22:59 -
Can I convert BD .mt2s files to MPEG-4 AVC/H.264 using TMPGEnc 4.0
By EdinburghKev in forum Blu-ray RippingReplies: 3Last Post: 20th Nov 2008, 09:10 -
Possible To Convert Pinnacle DC50 Captured Video?
By leebo in forum Video ConversionReplies: 13Last Post: 16th Nov 2007, 03:45
