as of lately ive ben having problems finishing my dvds, they usually get get to about 91% of the way done, then it just says writer error in nero, heres the log
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 8:06:00 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/29/2003 10:37:36 PM
Nero Version: 5.5.10.42
Recorder: <SONY DVD RW DRU-500A> Version: 2.0f - HA 1 TA 0 - 5.5.10.42
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SAMSUNG DVD-ROM SD-616F>Version: F102 - HA 2 TA 2 - 5.5.10.42
Adapter driver: <ultra> HA 2
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800AB-22CBA0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1000BB-00CAA1 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : SONY DVD RW DRU-500A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-224B atapi Port 1 ID 1 DMA: On
DiskPeripheral : WDC WD2000JB-00DUA0 65.1 ultra Port 2 ID 0 DMA: ?
DiskPeripheral : Maxtor 6E040L0 NAR6 ultra Port 2 ID 1 DMA: ?
CdRomPeripheral : SAMSUNG DVD-ROM SD-616F F102 ultra Port 2 ID 2 DMA: ?
CdRomPeripheral : PINE CD-ROM PT-56X Y01G ultra Port 2 ID 3 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 991MB (1015324kB)
Free physical memory: 487MB (498940kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
20.9.2003
UDF/ISO compilation
6:32:00 PM #1 Phase 112 File dlgbrnst.cpp, Line 1655
DVD-Video files reallocation started
6:32:00 PM #2 Phase 114 File dlgbrnst.cpp, Line 1655
DVD-Video files reallocation completed (no file modified)
6:32:00 PM #3 Text 0 File Isodoc.cpp, Line 7589
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
6:32:00 PM #4 Phase 111 File dlgbrnst.cpp, Line 1655
DVD-Video files sorted
6:32:00 PM #5 Text 0 File Reader.cpp, Line 115
Reader running
6:32:00 PM #6 Text 0 File Writer.cpp, Line 125
Writer SONY DVD RW DRU-500A running
6:32:00 PM #7 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
6:32:00 PM #8 ISO9660GEN -11 File geniso.cpp, Line 4571
6:32:00 PM #9 Text 0 File Burncd.cpp, Line 3745
Turn on Disc-At-Once, using DVD media
6:32:00 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2089696 (2089696) = #2089696/464:22.46
relocatable, CD pos for caching/writing not required/required, no patch infos
6:32:02 PM #11 Text 0 File DlgWaitCD.cpp, Line 225
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2089695 (464:22.45)
6:32:02 PM #12 Text 0 File DlgWaitCD.cpp, Line 230
Write in overburning mode: FALSE
6:32:02 PM #13 Text 0 File DlgWaitCD.cpp, Line 1700
Recorder: SONY DVD RW DRU-500A, Media type: DVD-R
Disc Manufacturer: LONGTE - N 001
Disc Application Code: 64, Disc Physical Code: 193
6:32:02 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder SONY DVD RW DRU-500A for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -14962688
6:32:02 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2089696 blocks [SONY DVD RW DRU-500A ]
6:32:02 PM #16 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 2x (2,760 KB/s)
6:32:02 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
6:32:02 PM #18 Text 0 File DVDR.cpp, Line 1443
Recording mode: Sequential Recording Mode
6:32:02 PM #19 Text 0 File Mmc.cpp, Line 18419
Set BUFE: Power-Burn -> ON
6:32:02 PM #20 Text 0 File DVDR.cpp, Line 1557
Start write address at LBA 0
DVD high compatibility mode: Yes
6:32:02 PM #21 Text 0 File Cdrdrv.cpp, Line 7929
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
6:32:17 PM #22 Text 0 File Writer.cpp, Line 316
18:32:17.061 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #23 Text 0 File Writer.cpp, Line 316
18:33:11.077 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #24 Text 0 File Writer.cpp, Line 316
18:33:11.686 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #25 Text 0 File Writer.cpp, Line 316
18:33:11.733 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #26 Text 0 File Writer.cpp, Line 316
18:33:11.811 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #27 Text 0 File Writer.cpp, Line 316
18:33:11.874 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #28 Text 0 File Writer.cpp, Line 316
18:33:11.936 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:33:11 PM #29 Text 0 File Writer.cpp, Line 316
18:33:11.983 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:34:25 PM #30 Text 0 File Writer.cpp, Line 316
18:34:25.639 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:35:40 PM #31 Text 0 File Writer.cpp, Line 316
18:35:40.233 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:35:40 PM #32 Text 0 File Writer.cpp, Line 316
18:35:40.264 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:36:54 PM #33 Text 0 File Writer.cpp, Line 316
18:36:54.827 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:38:09 PM #34 Text 0 File Writer.cpp, Line 316
18:38:09.483 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:39:24 PM #35 Text 0 File Writer.cpp, Line 316
18:39:24.030 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:40:38 PM #36 Text 0 File Writer.cpp, Line 316
18:40:38.624 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:40:38 PM #37 Text 0 File Writer.cpp, Line 316
18:40:38.655 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:41:53 PM #38 Text 0 File Writer.cpp, Line 316
18:41:53.233 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:43:07 PM #39 Text 0 File Writer.cpp, Line 316
18:43:07.921 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:43:08 PM #40 Text 0 File Writer.cpp, Line 316
18:43:08.014 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:44:22 PM #41 Text 0 File Writer.cpp, Line 316
18:44:22.608 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:45:37 PM #42 Text 0 File Writer.cpp, Line 316
18:45:37.171 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:45:37 PM #43 Text 0 File Writer.cpp, Line 316
18:45:37.202 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:46:51 PM #44 Text 0 File Writer.cpp, Line 316
18:46:51.843 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:48:06 PM #45 Text 0 File Writer.cpp, Line 316
18:48:06.483 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:48:06 PM #46 Text 0 File Writer.cpp, Line 316
18:48:06.514 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:49:21 PM #47 Text 0 File Writer.cpp, Line 316
18:49:21.139 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:50:35 PM #48 Text 0 File Writer.cpp, Line 316
18:50:35.796 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:50:35 PM #49 Text 0 File Writer.cpp, Line 316
18:50:35.905 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:51:50 PM #50 Text 0 File Writer.cpp, Line 316
18:51:50.421 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:53:05 PM #51 Text 0 File Writer.cpp, Line 316
18:53:05.061 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:53:05 PM #52 Text 0 File Writer.cpp, Line 316
18:53:05.093 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:54:19 PM #53 Text 0 File Writer.cpp, Line 316
18:54:19.686 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:55:34 PM #54 Text 0 File Writer.cpp, Line 316
18:55:34.296 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:56:35 PM #55 Text 0 File Writer.cpp, Line 316
18:56:35.061 - SONY DVD RW DRU-500A : Queue again later (Intervall : 23msec)
6:56:38 PM #56 SCSI -1135 File Cdrdrv.cpp, Line 1443
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02610000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x08
CDB Data: 0x2A 0x00 0x00 0x1C 0xBE 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x1C 0xB5 0x9B 0x12
0x00 0x00 0x00 0x00 0x0C 0x08
6:56:38 PM #57 DVDR -1135 File Writer.cpp, Line 333
Write error
6:56:38 PM #58 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
6:56:38 PM #59 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
6:56:38 PM #60 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 2x (2,760 KB/s)
6:56:38 PM #61 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 8:06:00 AM
File 'Drivers\Tpp200.sys': Ver=5.04.1150.0 , size=35541 bytes, created 10/5/2001 11:54:28 AM
File 'Drivers\Tpp300.sys': Ver=5.04.1150.0 , size=33669 bytes, created 10/5/2001 11:54:28 AM
File 'Drivers\Tpp725.sys': Ver=5.04.1150.0 , size=43269 bytes, created 10/5/2001 11:54:28 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.53a, size=17136 bytes, created 8/29/2003 8:54:39 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 8/17/2001 2:51:56 PM (Adapter driver for rec)
File 'Drivers\Ultra.sys': Ver= 2.00.0.34, size=25856 bytes, created 5/3/2002 10:44:08 AM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ireally and truly dont know the cause so if you can help please do, i wonder if its the media i have as well, these discs are just generic..holla back
Results 1 to 12 of 12
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
did you try different media? i had a whole spindle doing that same exact thing on my sony dw-u10a recently...basically erroring after 92-95%. The movie was great up till the ending when i viewed it. it did the same thing in nero and recordnow max. So i tried the disks in a diff drive and they failed again, i tried 3 other kinds of media and they all worked, so i took that spindle back, store exchanged them for a new spindle and i haven't had a problem since!
cool...ill just have to buy princo and maxell from now on...thanks bud
Did you find out the solution. I encountered the same write error when I tried to backup 3GB data to a +RW using Nero 6.0.0.19 & NEC-1300A:
I used the same disc and burnt it with RecordNow DX and Copy2DVD no problem was encountered in those softwares. So definitely Nero is the culprit.12:25:09 AM #20 Text 0 File WriterStatus.cpp, Line 113
<_NEC DVD_RW ND-1300A > start writing Lead-Out at LBA 1 (1h), lenght 0 blocks
12:25:10 AM #21 SCSI -1135 File Cdrdrv.cpp, Line 1413
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x03130000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x23 0x05 0x3F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
12:25:10 AM #22 CDR -1135 File Writer.cpp, Line 335
Write error -
I would not advise using Princo disks with your Sony. I used them and had lots of errors with them, particularly "queing failed errors".
I would recomend using Ritek disks. I've burnt quite a few of them now with very little problems.
i had the same problem with my dru500
i tried in 3 diferent pcs with nero (5.x.x.x and v6.0.0.0 / 6.0.0.15 / 6.0.0.19) and easy cd creator 6.x and i got that error at the end of the record process
i tried record now 1:1 and it work but really... this is not nero/ecdc problem, ive worked about a year and now i cant record nothing, i erased 2 pcs and install everything from the beginning (XP PRO - SP1 - NERO/ECDC)
conclusion: today im sending the sony for rma
and by the plextor 708a
p.s.: i already tried to change the firmware... 1.0d, 2.0f and 2.0g and had the same result -
All I can say, being the noob that I am, is that Nero caused me more grief than any other possible culprit. I am running the 500ULX through Firewire and one day I started having problems like you described.... found that reinstalling Nero resolved the problem - for a day or so, and it was back to coaster city....
Now using other sw - CopytoDVD and a few other depending on my needs... Other than that the Sony works fine for me and does just what I need it to...
makntraks -
Princo (printable top surface) -r work badly for me on by DRUW10A if burnt at max speed x4. At single speed they burn fine. Memored -r work fine at 4 speed, as do Panasonic.Originally Posted by lal
Try recording at a lower speed. Also make sure you have not got any fingerprints on the write surface. You normally only put them near the edge as you handle the disc, but that is the part you are having trouble burning to. -
handyguy,
Sony web site says the ASPI fix is not for XP. I have XP SP1.
For Windows 95, 98, and 98SE users who have received an ASPI error. The following download will repair the ASPI layer on your system if it has become corrupt.
I tried other unknow DVD+RW today and it worked fine. Only the
Memorex DVD+RW is giving problems.
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
All was well ...then whats the hell wrong with the sound
By qwerty00000 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 26th Sep 2009, 06:39 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
