  1. hi cananyone tell me if u can fit 1 divx movie onto any format instead of splitting it .
    also i have bought some 99min cdr's i have nero and i cannot get them to work anyone got any ideas .
    i have a few divx movies that i have downloaded and want to put them onto disk as they are taking up loads of room. any help would be most gratefull
    Apr 2002
    The State of Frustration
    You can load them into TMPGEnc, use a template, tweak it with an unlock template, lower the bit rate, and make the final output DivX. And the Bit Calc says you can fit a DivX on a 650 MB disk with a bit rate of 772.
    Hello.
  3. If you just want to burn them as data divx files onto a CD then you would do this as you would any other file. If you have some 900MB (99 min) CDR's then you can burn AVI files up to 900MB on these discs.
