Was wondering if anyone knows what the native mpeg encoder in Ulead VS7 is. Also, if anyone knows if I can use separate (i.e. Mainconcept or Canopus) encoders with VS7.
TIA,
JDC
I think all current Ulead products use "Mpeg.Now" and prior versions used "Ligos GoMotion MPEG software compression technology".
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Thanks - it's actually not v.good that's why I'm shopping around. Any idea about plugging in Mainconcept's Mpeg encoder? Would that work?
Thanks again,
JDC -
I don't know about that. I think I've read there's been a development to frameserve with TempEnc though. Might be worth a try.
If I re-find it, I'll post a link.
Found it. http://www.videotools.net/index.php?rub=guides&htm=announceuleadvideoserverplugin.htm
but I'm wrong - it's for MediaStudioPro. I use both, so I confused myself.
Sorry
But... if you ever moved up to MSPro - you can use Mainconcept -
Also - read somewhere (here) that Mpeg.now is "based on Mainconcept encoder". But I am not clear on what differences there might be.There's no place like 127.0.0.1
According to Mainconcept, Ulead uses the MC codec tailored to their software. I read somewhere that you can substitute some VegasVideo MC codec files for some of the new MC 1.4 files and they work. Also, substituting those files in Vegas will make Ulead VideoStudio 7 use them, too. Maybe somebody has tried this.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Hank's Mpeg-2 Encoder
By unclescoob in forum Video ConversionReplies: 80Last Post: 8th Dec 2011, 12:16 -
What is the BEST Mpeg 2 Encoder Today?
By jrodefeld in forum Video ConversionReplies: 43Last Post: 2nd Jul 2011, 15:28 -
which mpeg-2 encoder would you choose...
By deadrats in forum Video ConversionReplies: 28Last Post: 12th Nov 2009, 22:11 -
Ulead MPEG.Now Encoder Missing
By raouliii in forum EditingReplies: 1Last Post: 11th Dec 2007, 11:02
