After auto updating my svcd2dvdmpg+ today and setting pan and scan to on in the output stream section, now, no dvd folders and vob files etc are created when I author stuff (and the autoher dvd folder setting is on). I have tried this before with the two bin files I am using (but then the pan and scan setting was off), I know it worked then. I have since tried uninstalling and repairing the install, no effect. I am just left with mpeg files, at txt file and an xml file. Any suggestions?
Results 1 to 12 of 12
iGrumpyGuest
Tom DunlopGuest
You're not alone. I had the same problem. Prior to updating via the program's update feature today everything went smoothly, but now the process ends without creating VOBs (though it did create the empty VIDEO and AUDIO folders). Odd thing is that the "log" states that the program HAS created the DVD.
can you email me your log file?
evilnicGuest
well, I've tried that. but it doesn't work. the AUDIO_TS and VIDEO_TS folders are being created but there's no .vob files.
evilnicGuest
well, just my luck... my dvd burner broke...
i'll be back when it's fixed.
cheers! -
should be fixed:
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
help recovering DVD folders n vob files from deleted hard drive
By grafixx in forum ComputerReplies: 1Last Post: 16th Jan 2010, 15:44 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 04:13 -
Not getting Audio/VideoTS folders created for DVD
By LoafingOaf in forum ffmpegX general discussionReplies: 13Last Post: 30th Jun 2008, 20:23
