  1. i am trying to author with chapters, but in the chapters screen it says:
    Number of possible chapter Entry points: 1
    Here is the MPEG Analyze data from MPEG tools:
    MPEG1, PlayingTime=4010.064s, Bitrate=0bps, PtsOffset=0385s, 349295 packets
    Video Stream: Motion Video, 480x480, 29.97003fps (NTSC), 3000kbps
    Audio Stream: Audio Standard MPEG layer2 Joint Stereo, 48KHz, 128kbps
    CRC = CFEE5A64
    Size = 811761580
    mpeg user scan data: one or more bcd fields out of range for 'previous_i_offset': [00:0d.39]
    mpeg user scan data: one or more bcd fields out of range for 'previous_i_offset': [00:05.0b]
    mpeg user scan data: one or more bcd fields out of range for 'backward_i_offset': [00:08.0e]
    mpeg user scan data: one or more bcd fields out of range for 'previous_i_offset': [00:01.0c]
    mpeg user scan data: one or more bcd fields out of range for 'backward_i_offset': [00:0a.10]
    mpeg user scan data: one or more bcd fields out of range for 'previous_i_offset': [00:02.3b]
    mpeg user scan data: one or more bcd fields out of range for 'forward_i_offset ': [00:0a.1c]
    mpeg user scan data: one or more bcd fields out of range for 'previous_i_offset': [00:0a.0c]
    mpeg user scan data: from now on, scan information data errors will not be reported anymore---consider enabling the 'update scan offsets' option, if it is not enabled already!
    aps' pts seems out of order (actual pts 753.237400, last seen pts 753.270767) -- ignoring this aps
    aps' pts seems out of order (actual pts 768.686167, last seen pts 768.719533) -- ignoring this aps
    aps' pts seems out of order (actual pts 810.261033, last seen pts 810.294400) -- ignoring this aps
    aps' pts seems out of order (actual pts 996.046633, last seen pts 996.080000) -- ignoring this aps
    aps' pts seems out of order (actual pts 1009.226467, last seen pts 1009.259833) -- ignoring this aps
    aps' pts seems out of order (actual pts 1191.642033, last seen pts 1191.675400) -- ignoring this aps
    aps' pts seems out of order (actual pts 1765.849000, last seen pts 1765.882367) -- ignoring this aps
    aps' pts seems out of order (actual pts 2993.542133, last seen pts 2993.575500) -- ignoring this aps
    aps' pts seems out of order (actual pts 3080.328833, last seen pts 3080.362200) -- ignoring this aps
    Does anyone know what is causing this? If u need anymore info, ill give it...
  2. Thanx to your link, the problem in this thread was solved too!! :
    https://www.videohelp.com/forum/viewtopic.php?t=179116&start=0&postdays=0&postorder=asc&highlight=
    THANX!!
