What is the difference between an 'audio' CDR and a data one - apart from the price?
Can CDR/CDRWs marked as 'for audio' be used in a PC to burn a VCD?
i believe that 'audio' cdrs are meant for the standalone burners that you hook to your stereo. and data cdrs are for PC only.
so, no you can't use an 'audio' cdr on your pc to make a vcd.
did i get that right?
-mark -
No unfortunately you got it wroung! In a computer you can use either kind. Apparently on a standalone audio-cd recorder you can only use thew audio type.
The only difference between the audio only and computer CD-R's is that the audio only has a code at the begining of the CD-R that the stand a lone must find before it can start to record that is why the regular computer CD-R's won't work in these recorders, the stand a lones will not be able to read the regular CD-R's.
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 21:53 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
really screwy issue: PC will not read cdr-audio disc after it is burned
By mazinz in forum AudioReplies: 12Last Post: 30th Jun 2009, 23:38 -
Video CD & Audio CD in a CDR.
By divx2vcd in forum Authoring (VCD/SVCD)Replies: 5Last Post: 4th Aug 2007, 15:14
