Can anyone tell me if they have played DVD+RW successfully. I have just got a dvd burner and have made a backup dvd which works fine on one of my dvd players but not on the Dansai.
Results 1 to 16 of 16
I owned a Technika dvd player which was the same internals as the Dansai 852 (i bought it because i could not get a Dansai).
And it played DVD+RW discs that where recorded in my settop recorder
without any problems.
So i would imagine the dansai will play em, as long as the dvd rom drive
they use is the same.
If not you could change the Rom drive for one that reads all types of disc as its only a standard IDE Drive
same here :P
how are you authoring your content? How are you burning?
media (code)?
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Code?
If that CompUSA is Optodisc and that Philips is CMC it could be a reason.
It could...You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
www.dvdinfopro.com
I didn't say it was the media for sure! It could be...You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I have just tried another dvd rip to a philips dvd+RW which doesn't work in the Dansai, but works perfectly in the Philips dvd player.
What DVD+ media have you used in the Dansai successfuly?
Thanks -
My 852 has got very picky recently - it won't play some '-' discs that it played in the past (Traxdata, Bulkpaq green, and Infiniti) burned with VOB, Decrypter or Nero. Same batch discs burned lately in VOB with 'include UDF' unchecked seem to work.
All '+' I've tried are OK.Life is what happens just when you've got everything planned.
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 13:29 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 12:54
Works on mine, mind you everything works
