Quick question,
I was wondering if anyone knew the resolution of Video8 analog film (PAL). I've got a Sharp Video8 Viewcam... There's a lot of discussion about Hi8 but not much about Video8. Is the res superior to VHS?
<font size=-1>[ This Message was edited by: purejunk on 2001-10-05 06:26:10 ]</font>
Res is essentially same as VHS, but arguably less res than VHS in consumer grade cameras. Hi 8 would be roughly double regular 8 mm.
I capture from 8 mm all the time. 352x576, resize and filter to 352x288 with very nice results.
Matt -
Wrong, here is the correct resolutions
8mm - 250 lines resolution
Hi8mm - 400 Lines Resolution
these are the max resolutions 8mm can go down to 240 and some non sony Hi8mm cams were 370-380 resoultions.
Have owned 8mm cams and home decks since 1987. Hi8mm cams since 1997. -
Are you talking about pal or ntsc? Your figures are close for NTSC, but not PAL, which the dude was asking about. Don't even think of saying that 8 mm is BETTER than vhs.
Thxkid, I just love the WRONG statements! That is the perfect way to alienate yourself from others...
Actually, 8mm has the same resolution as VHS, about 220-250 lines of horizontal resolution, and Hi-8 has the double, over 400 lines.
video8 to DVD
By Paul Laviolette in forum Newbie / General discussionsReplies: 2Last Post: 6th Apr 2011, 08:32 -
video8 tapes to pc
By jbristow in forum Newbie / General discussionsReplies: 8Last Post: 25th Jan 2011, 20:42 -
Video8 to Computer
By mvtm in forum RestorationReplies: 15Last Post: 28th Mar 2009, 23:13 -
Video8 to DVD
By claral in forum RestorationReplies: 8Last Post: 9th Feb 2009, 13:57 -
Video8 Head Misalignment?
By frozentax in forum Newbie / General discussionsReplies: 6Last Post: 1st Dec 2008, 19:59
