My PC config.
XP 2100+
Abit KG7-lite VIA686B chipset
RAM 512
Window98SE
Hauppauge WinTV-PCI-FM model 145 tv card (CX881 chip)
My problem is that VirtualDUB is not able to detect the tv capture card. Thanks in advance for any help.
Have you uploaded the latest drivers from Hauppage? My Hauppage TV Go is a "keeper", and I use it when I want to capture in AVI.
Hello. -
Yes. I downloaded the latest driver from the Hauppauge website. Here they are :
wdm88x_21082
It's still giving the same problem.
VirtualDUB Capture Error
Error 418: Capture Device was not detected. -
Several years ago I looked into Virtual Dub and decided to not use it because it worked only with VfW drivers and not with WDM drivers. Not sure if that's still the case, or if it has been updated to work with WDM drivers. But I see you are using WDM driver so that may be your problem. Back then, there was a workaround called VfW wrapper or something like that. Do a search on "Virtualdub" and "wdm" and "vfw".
Thank you. Will search for the WDM wrapper.
I did a search in my pc and found this...
Vfwwdm32.dll - VfW MM Driver for WDM Video Capture Devices
Vfwwdm.drv - VfW MM 16bit Driver for WDM V. Cap. Devices
Wdmmdmld.vxd - WDMMDMLD Virtual Device (Version 4.0)
Does it mean that I already have vfw in my system ? -
Forget the official drivers. Download the latest btwincap drivers for your card.
To use them with virtualdub you have to install vfm2wdm wrapper.
Read this : http://www.virtualdub.org/docs_vfwwdm
Two tips:
1- when you insterting to the capture mode, feed your card with true video signal, not a blue VCR screen. Cards don't detect always this as a picture info (nvidia cards have this issue, but sometimes bt8xx cards also have it)
2- Since you use wrappers for virtualdub, you can't adjust stuff like system (PAL/SECAM/NTSC), your input source (composite, s-video, etc) or sometimes you can't even get the program detect the capture device (your case). So use the well known "trojan" method: Download virtualvcr and run it. Set input source, capture framesize and TV system there. Close the program when ready. Open virtualdub and insert the capture mode. Now, virtualdub is working OK for capture.
Also, I replied you to that old post of yours of how to make virtualdub work with wdm drivers -
BTWinCap link didn't seem to take.
Here's the main site:
http://btwincap.sourceforge.net/ -
Thanks SatStorm and gastorgrab. I have been keeping the Hauppauge WinTv Card for almost a year. Time to make use of it.
Hauppauge 1212 HD PVR & VirtualDub
By MakiManPR in forum Capturing and VCRReplies: 3Last Post: 23rd Oct 2011, 12:31 -
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 22:01 -
Hauppauge HVR-1300 and Virtualdub Cannot Capture
By JonnyAlpha in forum Capturing and VCRReplies: 5Last Post: 13th Feb 2010, 10:39 -
Hauppauge TV card + webcamXP
By relishman in forum Capturing and VCRReplies: 2Last Post: 4th Dec 2008, 01:24 -
choosing a HAUPPAUGE card
By npereira in forum Capturing and VCRReplies: 67Last Post: 31st May 2008, 05:41
