Hi this is my first ever post so please go easy on me!!
I have been trying unsuccessfully to backup a dvd. first of i don't have the original disk anymore just 2 images of it in CUE/BIN format.
1.
I decided firstly to see how good quality they were so using ISOBUSTER extracted the MPEGs from the BIN's. They worked great in POWERDVD good quality sound and pic.
2.
I then though i would burn the images on two separate CDs using Daemon-Tools, these seemed to work fine. but when i tried to play the disks in my standalone there was no sound! none at all, i searched through the whole movie and both disks... no sound. I tried burning the images in Nero 6, and the same no sound!
Thinking the problem may be with CD-Rs i have been trying now, unsuccessfully for about 2 weeks, to burn the two files to DVD-R using my NEC1300a with latest firmware 1.7, i have burned data disks fine.
I have been bouncing round forums for days now about demuxing, muxing, extracting and converting. i have downloading countless trial versions of software and i am almost ready to crack.
PLS ADVISE, i want to use my brand spanking new DVDR for something more entertaining then backup!!
ANY HELP MUCH APPRECIATED. TA
1 Post is enough for 1 question.
Right no real helpful repies as yet so could some1 just please look over my method to get a 2 CUE/BIN's on to a DVD-r to play on a standalone.
1. Extract mpeg2's using ISOBUSTER
2. DVD2AVI to create .d2v and mpa files (2 of each)
3.Open TMPGEnc and load both files using DVD PAL filter.
4. Finish up with another MPEG which nero wont burn to DVD??? -
Hi thanks for post. like i said i am n00b but i have picked up some stuff from these forums:
the files dont play in WMP (windows media player, yeah?)
do you have any links or info how to make VIDEO_TS from 2 mpegs extraced from 2 cue/bin image files?
How do i check TMPGenc?
i dont know about nero, i just followed a How-to on burning images back to CD, but i am mostly concerned about the DVDR
1st Post Hello EVERYONE!
By V12V12 in forum Off topicReplies: 17Last Post: 4th Mar 2009, 05:15 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
