Results 1 to 9 of 9
  1. I have a large back catalog of VCDs that I would like to put on DVD.
    I have successfully converted 3 files to the approriate audio standards etc but there are 4 or 5 that I am having problems joining etc.
    When I rip the disks to the hard drive I have 2 mpg files, but when I try to join them in TMPenc I am losing 20 - 30 mins of video in the final created file.
    I have tried joining them with joiner which comes out fine but when I de-multiplex (TMPenc) I lose the 20-30 of video and audio again.
    Can anyone help me ?
    I am running windows 2K if thats a help.
  2. Joining mpg's can be fickle. Several optioms are available to you.
    1. Join the mpg's then re-encode as one file with tmpgenc (quality hit though)
    2. Dont join mpg's, re-sample audio to 48000 and use tmpgenc dvd author-add new track then add file for each associated mpg, ie 2 mpg files within the track (chapter).
    3. Join mpg's and use svcd2dvdmpg to re-sample audio as this seems to ignore video end sequence markers and encodes the complete audio length.
    Mar 2003
    Uranus
    If I was doing it, I would process each file to a DVD compliant MPEG2
    separately, check that they play, and then
    put them into an authoring program.
  4. Join mpg's and use svcd2dvdmpg to re-sample audio as this seems to ignore video end sequence markers and encodes the complete audio length.
    I have tried this way and it hangs when demultiplexing. The video file is there alright but it just stops dead when trying to do the audio.
    The MS- DOS box pops-up but nothing is appears to be happening inside it.
    Could someone help me please.
    I dowloaded svcd2dvdmpg on Saturday Morning, so I imagine that is the latest version.
    Thanks for all your help already guys.
    Mar 2003
    Uranus
    Quit trying to join them. You are buying unnecessary problems.
    Process each one into the correct format individually .
    You said you wanted help.
  6. Quit trying to join them. You are buying unnecessary problems.
    FOO, thanks for your help. I have tried that and I am still getting the same problem.
    I was just thinking I have only got SVCD2DVDMPG and not SVCD2DVDMPG+. Is there a differnce ?
    Mar 2003
    Uranus
    Do you mean that the indivudual converted files will not
    play ? In WindowsMediaPlayer even ?
  8. It plays when I have ripped them from the CD.
    But after that all I am getting from SVCD2DVDMPG is 2 mpg files, Video only no sound. There are 2 audio files at 4k a piece.
    It just keeps hanging on me
    Cheers for helping me FOO.
    Mar 2003
    Uranus
    I have never used SVCD2DVD so I can't help. I do everything
    the hard way
