does anyone know how can i save A LOT of space when saving an .avi file in vdub? because i edited a 2:20 min. video and then i saved it as an .avi, the filesize of this vid is 1.40gb, so i want to know what should i do to conserve a lot of space after editing a certain video.
Click on video menu ensure 'direct stream copy' so it will save it in the same format (divx or whatever).
Or choose 'compression' on video menu to pick another format. -
Or if you are encoding the edited video to mpeg, there is no need to save it at all you can simply frameserve it to your mpeg encoder.
Help save HDD space!
By pocketrockets in forum Newbie / General discussionsReplies: 0Last Post: 29th Apr 2012, 07:03 -
Convert WMV2 video to h264 to save space, but without a quality loss?
By mkvbob in forum Video ConversionReplies: 11Last Post: 12th Apr 2012, 19:28 -
Does mono save space?
By Eddie the Editor in forum Authoring (DVD)Replies: 15Last Post: 30th Jul 2011, 11:47 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 17:55 -
If I want to save space of sizes, should I re-encode?
By rocky12 in forum Newbie / General discussionsReplies: 10Last Post: 29th Nov 2008, 15:17
