does any one know how can i install a vdub 1.4.9 handler? i think its the solution to my problem when im frameserving from vdub to tmpg.
In your virtual dub folder is an icon called "auxsetup.exe". Click on it and a new box will pop up. In the new box click on the "install handler" button. The handler will now be installed.
ive read this after searching the forum:
2. Using Vdub 1.4.9 (unistall the 1.4.10 handler and install the 1.4.9) - TMPG works fine.
so how do i uninstall the 1.4.10 handler and then install the 1.4.9? -
Go to the folder for virtual dub 1.4.10 and click on auxsetup.exe. When the new box pops up click on the "uninstall handler" button. Then go to the folder for virtual dub 1.4.9 and install the handler as before.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
Reversing PAL speedup and frameserving
By Ennio in forum Video ConversionReplies: 23Last Post: 28th Jan 2010, 16:28 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 18:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31
