I have a couple files *Xvid.avi and *Divx.avi that I have dl. When I load into Vdub-mp3 and scan for freezes it tells me that all of the frames appear to be good. If I preview the files they play about 15 seconds and then the video freezes but the audio continues. They do the exact same thing in TMPGenc. I have encoded numerous movies and have never had this problem before. Here is the kicker, if I open the files in Divx player, they work great.
I am lost can anyone give me a helping hand?
Peace,
gmpman
Wierd....try this. Before you encode, extract the audio and encode them separate. Not sure if this'll do anything...but since you've done it many times before one more time wouldnt hurt. Good lucks.
Prime Image Freeze II question
By pgoelz in forum Capturing and VCRReplies: 9Last Post: 12th May 2011, 17:39 -
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 10:10 -
wierd playback issue in MPC
By fix25 in forum Software PlayingReplies: 0Last Post: 26th Oct 2008, 16:03 -
More wierd Vista behavior...
By ahhaa in forum ComputerReplies: 2Last Post: 28th Jun 2008, 20:05 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 21:29
