What are your strategies and techniques for reducing the number of dropped frames when capturing ?? I got too many dropped frames from an old VHS tape.
My equipment is pretty new and more than capable : Canopus ADVC-100, fast 2.4 ghz cpu, new Panasonic VCR/DVD (PV-D4743). I have tried the following capturing software : Scenalyzer, WinDV, VirtualDUB, Ulead DVD Workshop Pro. My Panasonic VCR has auto head cleaning, auto tracking, and I tried to manually adjust the tracking. Nothing seemed to help.
So, what are tricks and tips to try to reduce the number of dropped frames ??
Correct me here : You are "capturing" VHS through your AVDC-100?
If this is the case, then any frame drops will be because of poor source and typically not your computer.
I even get frame drops from when I have removed / reinserted a DV tape and there is no data stream.
Try a TimeBaseCorrector , it seems to have solved a few issues for people.So, what are tricks and tips to try to reduce the number of dropped frames ??
Yes, I am capturing from a VHS tape.
What is a TimeBaseCorrector (TBC) ? -
1) read the capture guides
2) do a forum search on this topic
3) read this: https://www.videohelp.com/forum/viewtopic.php?t=157660 -
I want to second and amplify Andkiich's suggestions. This is a VERY commonly asked question and has dozens of possible answers. They have all been covered over and over again. That is why there is a sticky covering this, with multiple posts covering specific areas in great detail.
Once you have done these things, if you still have questions, then try again. -
This is probably the most inexpensive TBC I've seen...
http://www.avtoolbox.com/avt-8710.htm
I don't own one personally but there have been alot of recommendations for it here.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
