Has anyone encountered any problems doing simultaneous encodings using TMPGEc, other than slowing the process down?
No problem, you can do anything while you encode (even run another TMPGenc window) but as you said it will slow the process down. In my experience it slows it down to the point where it's faster to encode serially (use batch encode). But if you have a dual CPU system you can assign each TMPGenc project to use one CPU (although I suspect that might also end up taking more time than a dual CPU encode, not really sure).
It can be done and I used to do it when leaving the PC overnight. Of course that was before I "discovered" the batch processor built-into Tmpgenc.
One thing to note is that you need to set the priority to be low for both/all Tmpgenc windows running in parallel, otherwise one will take-up all CPU and the others will practically pause.
Also, no Tmpgenc instance must be foreground. Load calculator and make it the foreground task, just to make sure.The more I learn, the more I come to realize how little it is I know. -
It is better to use batch encoding. That way if you have a system crash your encodes up to that point will be ok. If you are encoding several files simultaneously you may find that none of them have finished and you have to start over again.
Help with simultaneous video outputs
By Rob #3 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th May 2010, 21:53 -
VCD with 2 simultaneous languages in audio.
By v-sharp in forum AudioReplies: 9Last Post: 4th Feb 2010, 06:29 -
simultaneous display of 2 subpicture streams?
By Radish in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2009, 02:31 -
Simultaneous video playout ?
By bertoa in forum MacReplies: 0Last Post: 9th Feb 2009, 08:06 -
Simultaneous video layering?
By SamZee in forum EditingReplies: 10Last Post: 15th Oct 2008, 07:13
