Here is what I did
1. Rip main movie using DVD Decryptor
2. used Tmpege Dvd Author to merge the 2 movies.
3. Try to use dvd2one to transcode the movies since it is bigger than 4.7 or 4.3hollywood, The problem is DVD2one will not transcode the movie, but instead an error pop up with something " Encrypted Data Protect" . What should I do? and How Can I get around this? Can i Decrypted my VOBs file with some time of program?
thanks,
john
John
I don't mean to be rude but your message is incoherent.
You ripped the main movie...
and then there are TWO movies
and then
EH ?some time of program?
Does you mommy know you are playing on the computer ?
[quote="FOO"]John
quote] shock horror, FOO actually realising he is rude and is trying to be nice
oh well, didn't last that longOriginally Posted by FOO
@accesscard18, when you talk about two movies are you talking about two files (audio/sound) or two movies you are trying to put onto one DVD? -
sorry for not making it clear....
some time = some type of program that I can get around it??
sorry,,,,, couple of shots gave me a headache..
it's not 2 movies... it is an episode (Band Of Brothers)....
The original Disc was 6.9 gigs ... but only 5.7 with only the main movie (which I want to keep)
First episode = 3.7 (Bother episodes are on one DISC)
2nd episoe= 2.5 or something like that if I remember it correctly...
I have merged the movies movies together using Tmpege DVD Author... but when I try to transcode it again using DVD2ONE,, it wouldn't let me... -
The easiest way I've seen is
http://www.dvdshrink.info/re-author-v3beta5-advanced.php
however at the moment the link seems inactive.
Shots of Tequilla do that to me
Decrypted VOB playback pixelated
By SiDon in forum DVD RippingReplies: 2Last Post: 4th Jun 2010, 08:50 -
decrypted, converted .vob to .mpg but have no menus
By chgoguy in forum Video ConversionReplies: 6Last Post: 8th Aug 2009, 17:03 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23 -
Decrypted DVD9 plays fine from harddrive, not when burned to DVD+R DL
By ndaher in forum DVD RippingReplies: 4Last Post: 7th Sep 2007, 15:35
