I encoded a 640x352 25fps to MPEG2 with the output setting: 720x480 and 4:3 NTSC. Source aspect ratio is 1:1VGA. The result is quite surprising when I view the result MPEG2 clip with WMP 9.0. When I view it in win2000. WMP9 showed a 720x540 resolution. But in winXP, it showed 640x480. I'm confused!! Which info is correct? I just want the video image size in the DVD to be the same as in the original Divx so that the quality is preserved. ANy idea?
Several points. The first is that since your source is 25fps (PAL) you'll need to convert that to a NTSC useable framerate (23.976fps or 29.97fps).
Also IF the DivX was correctly encoded it should have a DAR of 1:1. The aspect ratio for 640x352 is 1.81:1 (pretty close to 1.85:1 or academy flat). Since this is a DVD you have two choices, either make an anmorhic DVD and author with a 16:9 flag, or letterbox and author at 4:3.
From your post it's hard to tell which you did. We need to know what program/s you are using (TMPGenc?) and what settings/templates.
So there are two things you need to decide: a. how to get NTSC framerate, b. do I want a 16:9 anamorhic or 4:3 letterboxed video -
I used TMPGenc and with my own settings based on what I read on Doom9
Source: non-interlaced, 1:1DAR
Output: 720x480, 4:3, 23.976fps
My questions are:
1. What will happen when make the MPEG 23.97fps directly from a 25fps Divx in TMPG. Is the MPEG going to be OK? Why do I need to convert to 23.9fps first?
2. If I want a anamorphic 16:9, will I loose any quality since the original is 640 wide and the MPEG width is 852?
3. Do I get 720x540 or 640x480 MPEG if I want to do 4:3 letter box. Why do I get 2 different results when viewing in WMP9 in win2000 and winXP?
4. How do I preserve the width of 640 of the Divx file to get the best quality.
Divx playback problems on DVD Player
By pblunn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Feb 2008, 03:02 -
DVD players w/ Divx-HD playback?
By rogerconnery in forum DVD RippingReplies: 8Last Post: 11th Feb 2008, 02:36 -
DIVX Playback DVD player?
By Variable in forum Newbie / General discussionsReplies: 4Last Post: 25th Jan 2008, 18:39 -
DVD to AVI (DivX) playback strangeness
By vvw in forum DVD RippingReplies: 3Last Post: 11th Dec 2007, 22:34 -
dvd players with DivX playback?
By iThinkYouBrokeIt in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Nov 2007, 19:52
