I've ripped a load of my DVD collection to DVDR with DVD SHRINK Ver 3 (Beta) only to find that they don't play on the X-Box.
Any suggestions to correct this would be apreciated and also which is the best alternative software to use if the problem cannot be sorted ?
Results 1 to 10 of 10
It has nothing to do with DVD Shrink.
Its the media or the burning software or burning settingsYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Using good media is the first step. I use Ritek media and it always works on x-box and playstation2.
I have made most of my DVD copies using DVD2One and I know they play well, but have not tried to play the DVDs that I made with shrink on my x-box or play station, so I really don't know if that is a factor.
Please list your:
1. burner
2. firmware version
3. Media used and speed rating
thnx -
Why would anyone want to play a DVD on the X-Box when real DVD players can be had for as low as $40 (mintek 1600 for example). ?
Because that might be all they have. they might not want to clutter their entertainment center with another item.Why would anyone want to play a DVD on the X-Box when real DVD players can be had for as low as $40 (mintek 1600 for example). ?
I've backed up lots of movies with DVDShrink, and they al play in the XBOX just fine. It's probably the media or the way it was burned. I know that Nero has a special option just for XBOX compatibility. -
I think it's because i'm using nero express and not the full programme as this doesn't have the x-box option.
Dawn, just curious. Are you a woman? Just wondering cause we don't get too many females in these parts.
Hi all.
Dawn, here is a user-friendly Nero guide:
http://www.dvdshrink.info/nero-udf-iso.php
It was made with Nero 5 but the principle is the same if you use Nero 6.
Remember to check the "XBox" compatibility option.
One specific ripped DVD folder does not play in Windows Media Player
By aslaksen in forum Software PlayingReplies: 2Last Post: 11th Apr 2010, 19:16 -
Possible to author a 23GB DVD onto a BD-R and play it on a set top box?
By litmus in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Feb 2010, 16:42 -
Can't watch ripped movies on Panasonic DVD-F87
By arbutler in forum DVD RippingReplies: 5Last Post: 13th Oct 2008, 19:40 -
problem getting ripped dvd to play in my standalone
By rmb3 in forum DVD RippingReplies: 7Last Post: 25th Jul 2008, 05:16
